Install Bridge with Docker
Docker is a flexible install path for the Bridge Alpha and works best on dedicated Linux hosts, NAS devices, home servers, and power-user environments where host networking is available.
For most Windows and macOS desktop users, use the native installer instead of Docker Desktop. Docker Desktop port mapping is usually enough for the Bridge UI and outbound SharpTools Cloud connection, but many Bridge integrations rely on mDNS, UDP broadcast, Matter commissioning, or direct LAN reachability that Docker Desktop networking can make unreliable.
Bridge stores runtime data, pairing information, integration configuration, secrets, device state, and logs in a persistent data directory. In Docker, that directory is /data inside the container.
Docker Run
Run Bridge with a named Docker volume:
bash
docker run -d \
--name sharptools-bridge \
--restart unless-stopped \
--network host \
-v sharptools-bridge-data:/data \
ghcr.io/sharptools-io/bridge:alphaOpen the Bridge UI:
text
http://<docker-host>:8787/Docker Compose
Create a docker-compose.yml file:
yaml
services:
bridge:
image: ghcr.io/sharptools-io/bridge:alpha
container_name: sharptools-bridge
restart: unless-stopped
network_mode: host
volumes:
- sharptools-bridge-data:/data
volumes:
sharptools-bridge-data:Start Bridge:
bash
docker compose up -dOpen the Bridge UI:
text
http://<docker-host>:8787/Docker Defaults
The Bridge Docker image sets these defaults:
| Environment Variable | Default | Purpose |
SHARPTOOLS_BRIDGE_HOME | /data | Persistent Bridge data, including pairing, integration settings, secrets, state, and logs. |
SHARPTOOLS_BRIDGE_PORT | 8787 | Local Bridge admin UI port. |
SHARPTOOLS_BRIDGE_HOST | 0.0.0.0 | Network interface Bridge listens on inside the container. |
You usually do not need to set environment variables unless you want to change those defaults. For example, to use a different admin UI port with host networking:
bash
docker run -d \
--network host \
-e SHARPTOOLS_BRIDGE_PORT=8788 \
ghcr.io/sharptools-io/bridge:alphaWhy Host Networking Is Recommended
Linux host networking is recommended for the alpha because many local integrations depend on LAN discovery or direct device communication.
Examples include:
- mDNS discovery.
- UDP discovery.
- Local HTTP or WebSocket device APIs.
- Devices using the Matter protocol and Hue local network behavior.
Host networking is the simplest way to let Bridge see the same local network as the host.
Docker Desktop and Port-Mapped Networking
Docker Desktop is not the recommended path for most Bridge users. If you are a power user and still want to run Bridge with Docker Desktop, you may need to remove network_mode: host and publish the admin port instead:
yaml
services:
bridge:
ports:
- "8787:8787"
volumes:
- sharptools-bridge-data:/dataPort-Mapped Networking Limitations
Port-mapped mode is usually enough for the Bridge UI and outbound SharpTools Cloud connection, but it can break or limit mDNS discovery, UDP broadcast discovery, Matter commissioning, and direct local device communication. Some integrations may require manual host/IP entry, and some may not work reliably compared with Linux host networking or the native desktop installers.
Persistent Data
Bridge stores important data in /data including Integrations, Cloud Authorization, Logs, and more.
DANGER
Do not delete the data volume unless you intentionally want to reset Bridge.
Updates
Bridge does not update the Docker image from inside the container.
Docker Compose
To update a Compose install:
bash
docker compose pull
docker compose up -dDocker Run
To update a docker run install, pull the latest alpha image, recreate the container, and keep the same named data volume:
bash
docker pull ghcr.io/sharptools-io/bridge:alpha
docker stop sharptools-bridge
docker rm sharptools-bridge
docker run -d \
--network host \
ghcr.io/sharptools-io/bridge:alphaThe Bridge UI can check for available updates from System > Updates and show deployment-specific guidance.
Reset
To fully reset a Docker install, stop the Bridge container and remove the data volume.
Reset Deletes Local Bridge Data
Resetting Bridge deletes pairing, integrations, runtime state, secrets, and local logs. Only do this if you are intentionally starting over.
